Hotpoint Aquarius Rear Condenser Pump Not Kicking In
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint Aquarius Rear Condenser Pump Not Kicking In
  • #100687
    David Hughes
    I have a Hotpoint AQC9 BF7 E tumble dryer. Has been leaking water from underneath. Recently decided to clean out fluff from the rear chamber where the condenser pump is located. The rubber impeller had broken too – so fixed that. Continued to leak water and the pump was running intermittently, so decided to replace the pump with a new one. However, now both the new and old pump do not kick in and no water is being collected in the top water tray.
    Have confirmed that the float switch is OK (using a multi-meter in continuity mode) and have detected voltages in the connectors for the pump (approx 16v) and the switch (approx 25v). I think it would be really unlucky if both pumps were dead. Is there something else that could be stopping the pump from turning on? Slightly confused why both might not be working when there is a voltage in the connector. Thanks!
    #481760
    well the pump is energised by the board in response to either time or the float micro
    if you lift the float does the display show water full ? you may have to leave it a few minutes as it may not be instant
    David Hughes
    If I turn on a cycle currently, I just keep getting the h20 error and the machine stops. Presume the h20 error is because the float switch is activated.
    #481762
    well that proves the board is sensing the switch
    check the pump wiring to the board and inspect board for damage in the circuit that controls the pump
    David Hughes
    Still no joy with getting this to work. I did find some minor damage to the pump power cable which I fixed with electrical tape (caused by cable jammed in the pump enclosure. Is there a way I can test the pump/switch is working separately to the machine? Im perplexed…if the pump and switch is working and the connectors are verified to be receiving power from the tumble fryer…what else could it be?
    #481764
    be careful
    when you raise the full switch the pump on some machines does not kick in straight away and may take 5 mins
    when you say the pump sw i assume you mean the container full sw. that can be checked with a multi meter on the buzz setting
    David Hughes
    Hi Dave,
    I’ll try holding the switch for 5 minutes or so to see whether it kicks in. However, something isn’t working properly because when I run a cycle I keep getting the H20 error and the tumble dryer cuts out. The tubes leading to the water try are free of blockages.
    Any ideas of anything else I could try?
    #481766
    have you looked at the board, found the pump connections and
    A verified the pump wiring
    B looked at the board for damage to pump control components
    David Hughes
    From doing some further research, it suggests that there are 3 water collection spaces….the tray that you empty, the box with the pump in at the rear and another area prior to this inside the condenser….could be possible that water is trapped in the first collection area and that’s why I am getting the h20 error. Maybe the pump is in fact functioning. How can I access this first water collection area? Any ideas? It might be full of fluff…
    #481768
    since the sensor is next to the pump I doubt thats a problem
    the way I test most of these is with the lid off and the draw out. pour a few cups of water into the tray (slowly).This will travel down the return pipe directly to the pump area. it should then pump it back up again
    still think the way you are telling it the fault may lie in the board or wiring to pump
