Hotpoint Aquarius SDW60 Dishwasher “Heat/Burning Smell”
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Aquarius SDW60 Dishwasher “Heat/Burning Smell”
  • #69861
    scoopd
    We noticed an abnormal smell in coming from what appeared to be the top of the dishwasher.When we took the appliance out it seemed that one of the pipes had been lying against the black back of the dishwasher.The pipe had left an indentation on the black back as though it had melted against it.The pipe its self also had what appeared to a brownness against the corresponding area.There also appears to be a kind of “bubbling” all over that black back panel(not sure if that was always there or not).
    Obviously we didn’t realise that the dishwasher had been pushed so far in the this pipe would touch the back of the dishwasher.However it has been in the same place for a few years without issue.
    1st time we ran the machine and noticed a smell it was on a normal wash and arose before the drying stage.
    Basically just wondering what it could be and whether it’s worth getting an engineer out or it could be too costly a job to be worth it.
    We obviously have turned the machine off until repair.
    Many Thanks
    #376213
    Re: Hotpoint Aquarius SDW60 Dishwasher "Heat/Burning Smell"
    When you say one of the pipes, is it the fill hose or the grey corrugated drain hose?
    The back of lots of dishwashers are exactly like this, its a layer of black bitumen soundproofing. It is black and bubbly and does get warm and stick to anything pressed against. It is not uncommon for the mains plug to actually stick to the back of the dishwasher if it is located there.
    I would pull the machine forward five or six inches and run it on a normal wash cycle without and dishes or detergent in it first. Keep a close eye on it during this time and see what happens. If you still get a strong burning smell then switch it off and get it looked at.
    #376214
    scoopd
    Hi,It’s the grey hose.From what you say the bitumen seems to not be the issue.It definately seems to be coming from the top of machine.Will try what you say.
    #376215
    There are no components at the back, top of the machine. 😕
    #376216
    scoopd
    Smell seems to be coming from the top of the machine
    #376217
    Allsorts
    Is the smell an electrical type smell or a plastic type smell.. it could be coming from the base of the machine and rising up inside the side panels to the top.
    #376218
    It could be coming from the top of the door, lots of bits and pieces in there, if it is still making the smell then you should not use it again until it has been checked over.
