Hotpoint Aquarius Soap Tray Leakage
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Aquarius Soap Tray Leakage
  • #9943
    8larch
    The soap tray leaks water every time the washer/dryer is turned on. I can’t see any evidence of there being a seal that is faulty and am baffled as to how to stop the leak. Any ideas?
    #136863
    Re: Hotpoint Aquarius Soap Tray Leakage
    Soap hose blockage? Difficult to say more without the model number……..
    8larch
    Model is WD63
    Thanks;
    #136865
    litlor
    if it floods out as soon as the water enters the machine
    Then dispenser/tub blocked with soap as advised by Penguin45 or if it
    Just dribbles out it is usually the dispenser top that needs changing
    can be cleaned does not always work
    #136866
    litlor
    part number for Dispenser Assy 1602579
    #136867
    Also very high water pressures can cause the occasional dribble from the drawer, more so if you have a combi boiler, make sure that the whole of the drawer and the surround is clean and completely free of soap deposits. it can set like rock and prevent the drawer closing correctly. If your pressure is very high, try turning the pressure down a little using the two taps usually fitted behind the machine or under the sink.
    #136868
    litlor wrote:part number for Dispenser Assy 1602579
    Is that still available as a complete unit ? PF does not recognise it now.
    Must admit I have never had to change a complete dispenser to cure a leak.
    #136869
    litlor
    yes only last week i changed one for the very same fault and it worked (so far) part number we got from SEME thats dispenser complete
    #136870
    litlor wrote:yes only last week i changed one for the very same fault and it worked (so far) part number we got from SEME thats dispenser complete
    Could be old stock then, but with PF you never know. 😉
    #136871
    Tocano
    iadom wrote:Also very high water pressures can cause the occasional dribble from the drawer, more so if you have a combi boiler, make sure that the whole of the drawer and the surround is clean and completely free of soap deposits. it can set like rock and prevent the drawer closing correctly. If your pressure is very high, try turning the pressure down a little using the two taps usually fitted behind the machine or under the sink.
    I have been having the same trouble recently. could it be due to my combi being serviced and the water pressure now higher. I have closed the 2 input taps slightly and this seems to have cured the problem.
    #136872
    Combi boilers are very often a cause of leaks from the dispenser drawer.
    #136873
    Martin114
    Blockage in steam condenser maybe? (tank vent)
    #136874
    Tocano
    Thanks for the advise, I will check that also.
