Hotpoint Aquarius SuperPlus DF22 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Aquarius SuperPlus DF22 Dishwasher
  • #41038
    OLLIE2806
    The cust puts the above m/c on prog 3, the m/c works ok untill it reaches number 5 on the dial the cust then has to click the m/c on 2 clicks and then the d/w carries on and finishes off.
    The element is o.k, so now I’m thinking it could be at the rinse so possibly a valve fault or failing that the timer, Any thoughts would much appreciated.
    Thanks in advance
    Ollie.
    #268581
    hotpnt
    Re: Hotpoint Aquarius SuperPlus DF22 Dishwasher
    check all the wiring where it passes from door to base, some may be cracked/oc
    #268582
    timdowning
    Have you cleaned out the black sump hose?
    #268583
    OLLIE2806
    Yep the hose had some stuff in it but nothing to write home about, and the wires seemed fine but heading back tues so i’ll give them a thourogh check over then.
    #268584
    hotpnt
    ask her to put on b4 you go & leave it where it sticks, the ones ive had like this always stuck at the heat stage due to broken wires
    #268585
    OLLIE2806
    thanks alot mate. will do.much appreciated
