hotpoint aquarius tcm 570 how to access pump
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum hotpoint aquarius tcm 570 how to access pump
  • #75024
    frogger
    hi i have a tcm 570 and dont know how to access the pump as its not heating and water light on and no water in tray and photos etc would be great many thanks
    #393631
    Re: hotpoint aquarius tcm 570 how to access pump
    Pump is at the back, in the small grey plastic housing.
    #393632
    frogger
    Hi iadom,Thanks for the reply iam not too good using a computer so excuse my punctuality,do you know how to remove the cover thats what IAM HAVING TROUBLE WITH,also will there not be heat if there a poblem in this area just was reading on other site,I have took out filter bottom left front of machine and tilted machine forward and some water ran out onto floor,the machine water light went out and it worked away then for a while heated up, but its is back to the same again light on and no heat many thnks in advance..
    #393633
    It is important to clean the filter in the door after each use and the large metal condensor every week or so, flushing through with a hosepipe is the best way to clean this.
    The pumps are prone to failure, the impellor often falls off. 😥
    The pump housing is a rather daft design and it is very difficult to remove it without breaking at least one of the plastic lugs that slot through the back. you just have to use a flat bladed screwdriver and fiddle them out as best you can.
    The whole pump and float assembly will then lift clear. If the float chamber fills and is not pumped away then it will switch the heater off.
    #393634
    frogger
    Hi I have taken the pump out and noticed the small rubber impellor off the plastic shaft would this be the cause.also can you replace the impellor or is it a new pump that is needed
    many thanks.. :rolls:
    #393635
    Complete pump, part number C00193127, around £23/£25.
    #393636
    frogger
    cheers iadom for your help.
    #393637
    frogger
    thanks for the help the problem was the drain pump. easy enough to fit only catch is trying to remove the cover that hides the pump and water chamber. clips that hold it in to place are very tight to open .
