Hotpoint Aquarius TDC30
  • #42680
    dnaxton
    Hotpoint Aquarius TDC30 (Condenser Type)
    I have a question was does the brass/copper strip in this photo do.
    Basically what’s it called and what’s it’s purpose in life
    Regards
    Springnuts
    Re: Hotpoint Aquarius TDC30
    Hi dnaxton
    Looks like a Snurble Grip Thribley to me – but it’s an unusual design. Is the machine a ‘grey’ import from the continent perhaps?
    Regards
    Springnuts
    #274416
    dnaxton
    Springnuts wrote:Hi dnaxton
    Regards
    Springnuts
    Cheers for your very help reply.
    The Snurble Grip Thribley is the part behind the brass/copper strip.
    Earth strap. No longer fitted on newer machines as the drum now runs on a phosphour bronze bearing rather than the old Polypenco plastic one.
    dnaxton
    Basically i have just noticed that mine has worn through.
    #274419
    dnaxton
    Penguin45 wrote:Earth strap. No longer fitted on newer machines as the drum now runs on a phosphour bronze bearing rather than the old Polypenco plastic one.
    Would this cause my machine to blow a plug fuse
    Regards
    P/no C00199479 if you’d like to get a replacement. spares@ukwhitegoods.co.uk will get it for you promptly.
    dnaxton wrote:Would this cause my machine to blow a plug fuse
    No.
    Causes – water getting into fan chamber and being thrown into the elements is a good one. Exploding motor start/run capacitor is also common.
    NO.
    #274423
    :waving:
    Afternoon, Jim.
    :p45:
    #274424
    dnaxton
    Penguin45 wrote:
    No.
    It only blows a fuse when being used on the Hi Heat setting
    Low heat is fine
    #274425
    helo_75
    so the elements gone… or theres something (like a bra wire) touching the element!
    remove rear banjo shaped panel and have a good look
    plug out of course
    #274426
    dnaxton
    helo_75 wrote:so the elements gone… or theres something (like a bra wire) touching the element!
    plug out of course
    Update:-
    I have checked for foreign objects touching the element, none were present.
    What I have noticed is that the clothes are drying quicker now on low heat than when we used Hi heat. (Before the problem)
    Hi Heat just trips the breaker as it seems to get to hot. (I have a Safety breaker fitted to the end of the plug)
    Low heat is also a lot hotter than before
    So the question is
    Is it a faulty element or is there a heat controlling unit inside somewhere.
    Regards
    dnaxton
    plug out of course
    Update:-
    So the question is
    Regards
    Any thoughts
    #274428
    Low heat works, high heat trips the breaker. High heat works by turning on a second set of heater coils. The heater is knackered, as per Helo_75s post.
