Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpoint aquarius vtdoo blowing 13amp plug fuses.
- This topic has 8 replies, 2 voices, and was last updated 16 years, 10 months ago by
glennkieron.
June 19, 2009 at 8:14 pm #46494
glennkieron
Participantcan someone please help me. on putting a load on in my tumble drier after about half an hour the trip switch for my plug sockets went. reset this and found it was the 13amp fuse on my plug. i replaced this 3 times, the second 2 times as soon as i tried to start the drier the fuse blew straight away. i have realised there is an obvious problem and haven’t tried it again as to not damage the drier itself. i have taken the back and sides off my drier and cleaned it all, i have cleaned all around the seal on the drum, pulled the filter and cleaned the area where it lives as well and also cleaned the flexipipe and the entrance to this. should i give this another try now or should i inspect for something else first? hopefully someone will be able to help me. thanks.
June 19, 2009 at 8:26 pm #289638helo_75
Participanthow old is it?
earllier models were prone to the drum rubbing through the back plate and cutting through the heater wiresif you look just above the motor, where the drum meets the back panel, youll be able to see if its cut through.. the wires run quite close to that point
however you look at it, itll be a heater fault
June 19, 2009 at 8:43 pm #289639glennkieron
ParticipantRe: hotpoint aquarius vtdoo blowing 13amp plug fuses.
helo thanks for your quick response. the drier is 3 years old. i am at work right now but will check the wiring when i get home thanks again.
June 19, 2009 at 8:50 pm #289640helo_75
Participantyep, about the right age
has is been noisy for some time?
June 19, 2009 at 10:00 pm #289641glennkieron
helo if your talking about a grating sort of sound intermittently. then you’ve hit the nail right on the head. it’s been doing that for about 8 months now.
June 20, 2009 at 9:28 am #289642helo_75
Participantwell, thats the answer then, the only real cure for that is a new drum if thats the case
but you can try packing the drum out with a couple of washers on the shaft
June 20, 2009 at 6:24 pm #289643glennkieron
you were exactly right i did find the hole where you said, i also found the offendind wire as you said. i have managed to secure a small piece of metal over the hole and re-insulated the wiring. however now my drier runs fine (and makes less noise then before) but the heating element doesn’t work. could it be that the wire that got damaged could need rejointing or is there an internal fuse or other componant that could be damaged. hopefully someone will be able to help me cheers.
June 20, 2009 at 6:48 pm #289644helo_75
Participantcheck the wire, it could be broken
it could also be the cut out, theyre situated just over the heater
experience would suggest a damaged wire
June 25, 2009 at 2:18 am #289645glennkieron
helo_75 you were absolutely spot on with everything, my drier is now back up and running and the wife’s stopped nagging. can’t thank you enough for your help. cheers again. glenn.
