*** HOTPOINT AQUARIUS WASHER/DRYER WD 420 – TRIPS OUT ***
Home Forums Public Support Forums Help And Support Washing Machine Help Forum *** HOTPOINT AQUARIUS WASHER/DRYER WD 420 – TRIPS OUT ***
  • #76169
    yikes
    Problems to date:
    1. Dryer + on/off light flashes. – checked both heating element with multimeter which showed continuity.
    (Continued to use machine for wash only cycles – worked fine for awhile.)
    2. Some cycles did would not fully spin leaving clothes wet on finishing.
    (Continued to use machine still.)
    3. On switching on machine fuse in plug blows.
    Any help would be appreciated.
    #397453
    Re: *** HOTPOINT AQUARIUS WASHER/DRYER WD 420 – TRIPS OUT **
    A faulty element will always show “contunuity” and a multimeter is of little use establishing if that is due to an earth leak. The fuse going therefore concludes there is a likely problem there. Also the motor and the wiring harness need careful inspection whilst you’re at it! 😉
    #397454
    yikes
    Thank you for the advice. Some more would be good 🙂
    1 When you say there maybe an earth leak what exactly do you mean and what should i check/look for?
    2 On checking wiring harness if you mean they should be fully plugged-in and therefore connected then i have done this already and therefore there doesnt appear to be any loose connections.
    3 How do i check the motor? ..do you mean removing it and then checking with a multimeter?
    #397455
    An earth insulation leak is where current is leaked to earth simply because of a breakdown in its electrical insulation. (eg: water leak on electrics, elements internal insulation broken and voltage passing through goes straight to earth).
    The wiring harness to and from the heater and motor can rub against the cabinet and thus blow a RCD or 13amp fuse. And of course in order to check out the motor correctly removal is necessary.
    Messing with electrics without this knowledge is dangerous in the extreme and my best advice for you is you seek professional help. Check out the engineer search facility on the Home page. 😀
    #397456
    yikes
    Thank you martin
    given what you know thus far…i dont suppose you have a ball-park figure for how much the repairs might cost?
    am contemplating buying new
    #397457
    A bit like asking me “how long is a piece of string?” in essence. 😉
    #397458
    yikes
    yes i thought you might say that…its puzzling…what to do…lol
    dont suppose you get to nw2 much? 😉
    #397459
    yikes wrote:dont suppose you get to nw2 much? 😉
    No sorry my leash doesn’t stretch that far. 😀
