Re: Hotpoint Aquarius Washing Machine sudden no sign of life
The most common reason for this is the door locking device failing. There is a short time delay where the locking device engages and as the machine gets older the delay period gets longer and longer until it fails altogether. If the symptoms I describe relate in your case then you need one of these.
:zap: POWER OFF BEFORE ATTEMPTING TO INVESTIGATE :zap:
If you would like a local engineer to call and fix it fit it for you then please click on the link below. 😉
