Hotpoint Aquarius WD420 – Flashing Lights Error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Aquarius WD420 – Flashing Lights Error
  • #72172
    caseylife
    I have a Hotpoint Aquarius WD420. The light On/Off button light on the right and the top two lights on the vertical bank of five, top two are the Drying High Heat and Reduce Creases lights are all flashing after turning on the machine. I have moved the machine carefully from one flat to another then this has happened. Any help would be much appreciated. Steve
    #383713
    Allsorts
    Re: Hotpoint Aquarius WD420 – Flashing Lights Error
    in the circumstances you have describedI would say it indicates that you have pulled a wire off the control board
    #383714
    caseylife
    The advice has worked, the machine does now work to a point.
    I have two Hotpoint Aquarius wd420. Both machines work fine in flat ‘A’ I have used both as a replacement in flat ‘B’. Both machines when moved to flat ‘B’ do not work. Then when move back to ‘A’ both work. The water flows continuously on any wash cycle in flat ‘B’ and wash does not happen. The water pressure is strong, I can see it run through the soap tray. Is it too strong?
