Hello All,
When set to drying mode, on startup it pumps about two mug fulls of water into the dispenser which then empties into the drum. My question is, is this normal?
I would appreciate any advice given.
Paul
Hello iadom,
Many thanks for your reply. I am not familiar with the machine which is my sons who was convinced it was faulty and for some reason needed a new circuit board. I wasn’t so convinced since the amount of water did not seem to be excessive.
So many thanks once again for your kind help.
Regards
Paul
It’s odd why lots of people instantly think that any fault, real or imagined is caused by the pcb.
Granted the ones used in this Indesit made machine are not the best by a long way but you would be amazed at the number of folks who stick in an expensive pcb or timer that is not needed. They usually end up wrecking the machine at the same time. :rolls:
