hotpoint aquarius wdal 8640
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint aquarius wdal 8640
  • #85734
    needshelp
    I have a hotpoint aquarius wdal 8640 washer dryer. I put it on a 12 cycle which is a cotton drying cycle, however instead of drying out filed up with water. I let the cycle finish in the hope with would drain but it didn’t and instead just showed the ‘end’ and ‘lock’ lights glowing continuously. I then put it on a spin and pump cycle but again it started filling up with water then hummed loudly. I paused it not knowing what to do then later pressed play and it started draining. Finally I thought I was having some luck but it hasn’t drained fully. The dry light and the lock light are on continuously and now all the bottom five lights are flashing. What do I do?
    #429427
    Re: hotpoint aquarius wdal 8640
    Have you checked or cleaned out the drain pump filter?
    From bottom to top by number, which of the lower five right hand, VERTICAL lights are on steady?
