My parents in law washing machine has stopped working and all the lights are flashing rapidly from left to right. Only the door lock (red) is lit on the vertical lights at right hand side.
I have checked hoses for blockages (none), pump seems to be working fine (removed and refitted).
Could this be a heater element problem? Is it an easy fix?
When you turn machine on, everything is normal for 1-2 minutes. I can see water feeding through dispenser etc. After that, the light start flashing and water is pumped out the waste.
Thanks for any help.
Drewb
