Hotpoint Aquarius WDL540 Problem Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint Aquarius WDL540 Problem This topic has 2 replies, 2 voices, and was last updated 10 years, 10 months ago by Rswellian. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts June 19, 2015 at 7:35 pm #85311 RswellianParticipant Hi My washing machine spins for about 10-15 mins then stops with the door locked illuminated and the dry light (1 and 3) I have emptied it once and checked for blockages front the bottom front but it was fine. Anybody know what the error code means? Many thanks June 19, 2015 at 8:25 pm #428318 iadomModerator Re: Hotpoint Aquarius WDL540 Problem That error code does suggest it is not emptying correctly. Could be something jammed in the pump impellor, blockages in undersink hoses etc. Remove the pump filter and shine a torch inside to see if anything such as a bra wire or hairgrip is stuck under the pump impellor. June 19, 2015 at 8:52 pm #428319 RswellianParticipant Re: Hotpoint Aquarius WDL540 Problem As I replaced the u-bend under the sink the part with the waste hose goes into had a stopper which jammed into the waste hose. (Blonde moment) Removed that and it looks like it working now. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
