Re: Hotpoint Aquarius WF 430 flashing lights
That is a heat related problem, which possibly ties in with your comment about an item of clothing being shredded. The heater could have been damaged by the clothing or whilst trying to remove it.
You need to be checking the heater, resistance should be around 30 ohms (when isolated from the circuit) and also check it with an isulation tester because it sounds like it may have an earth fault.
If it is a faulty heater it is available here:
http://alturl.com/sfd3
Alternatively if it is not the heater it starts to get a little more complicated so one thing at a time.
If you are going to have a look your self, pull the plug and make sure it’s the correct plug-:plug: :zap: :zap:
