Hotpoint Aquarius WF000 won’t do spin cycle
Tried when empty and spin cycle only but only turns a few times slowly then same in other direction then have to turn off to reset
Not enough details really but if the brushes are ok, theirs no earth leak, the machine can drain & theirs no bad connections anywhere it looks like it could be the module as there notoriously unreliable.
Sorry for being so vague, but thanks for reply.
It does drain ok and the rest of the programmes are fine but when comes to spinning it will not reach full speed,it just does a few turns each direction and stops.
Are you referring to the main motor bushes?
I presume if its the module it’s not economically viable as its over 5 yrs old.
Thanks again.
