Hotpoint Aquarius Wf240 Heater relay stuck?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Aquarius Wf240 Heater relay stuck?
  • #57361
    yeppykinksta
    Hi there
    Recently my hotpoint WF240 washing machine has been flashing when switched on, the lights which flash are:-
    On/off – Fast repeating
    1.
    2.Reduce creases –
    3.Rinse hold – All flash together slowly.
    4.Time saver –
    5.
    I contacted hotpoint customer services and they said “The lights flashing indicate error code F07” then gave me a direct link to the error codes page, which indicates its a Heater relay stuck fault.
    Was wondering if I could get any advice/guidance on fixing this problem, would be greatly appreciated.
    Cheers, Dave.
    #330935
    odom
    Re: Hotpoint Aquarius Wf240 Heater relay stuck?
    Heater relay is integrated with the Indesit-build PCB. Check connections between PCB and heater but almost always you will need a new/reconditioned PCB, which isn’t cheap.
    #330936
    yeppykinksta
    Thank you for your reply ๐Ÿ™‚
    I’ve checked the wires and they all seem intact ๐Ÿ™ Theres a shop on ebay that will repair my module of PCB forยฃ42 with a 12month guarantee, would you recommend this?
