Hotpoint Aquarius WF250 lights 2,3 and 4?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Aquarius WF250 lights 2,3 and 4?
  • #70683
    nutbar
    I’ve searched for this specific combination of error lights but didn’t find anything. The problem started a week ago when the wash was on for over 2 hours (on a fast wash), had to turn machine off and on and changed to rinse and spin. Since then it starts to wash and then lights 2,3,4 flash(Reduce creases, rinse hold and time saver) while the on/off light flashes faster than the other lights. If I unplug and put on rinse and spin it will finish the wash. Any ideas what this might be please?
    Thanks.
    #378689
    Re: Hotpoint Aquarius WF250 lights 2,3 and 4?
    Heater fault, either the heater itself is open circuit or there is a fault on the main pcb, or possibly a broken wire somewhere.
    #378690
    nutbar
    ok thanks. is there a guide on how to check these and/or where they are in the machine so they can be checked?
    #378691
    A guide? Afraid not,if you do not know how to test electrical components then you should not be attempting to repair them.
    #378692
    nutbar
    Thanks very much for your accurate diagnosis!! The heater tested faulty and has now been replaced. The washer is now working!
