HOTPOINT AQUARIUS WF430
  • #16314
    leway
    when spinning with load there is a very loud knocking noise, when empty it sounds fine. Any suggestions to resolve this problem.
    #169241
    mutley
    Re: HOTPOINT AQUARIUS WF430
    Hi leway
    it sounds as if you have a loose top weight, will need tightening, BUT NOT TOO TIGHT, or you will snap the mountings on the drum
    john
    #169242
    Power off if removing any panel………..
    leway
    Many thanks John – problem solved.
