Re: Hotpoint Aquarius WM62 coin inside?
Most washing machines you’d have a hunt around through the sump hose and heater first but to be honest taking off the front of the drum on a WM is so easy best just to do this.
Be careful not to damage the heater when taking it out/putting it back in. Also, in the trade we use a special adhesive to reseal the front of the drum back on – if you don’t have this be extra sure it’s not leaking. You may want to run a band of silicon sealant around the edge to be on the safe side :).
