My mum has a Hotpoint WM64 that seems to fail to spin about 1 in 3 times. When it doesn’t spin it will just be sat there with the drain pump humming. Every time i’ve been there to watch it its spun, so I can’t tell if its aborted the spin mid way or just not tried.
As far as I can tell though it hasn’t as the clothes are very wet. I initially thought she’s been overloading it but it has been doing it a lot, and it hasn’t done it before recently and she’s had it 10 years. I’ve tried telling her to put less in for a week or so and see if it stops doing it but its like talking to a brick wall.
Whenever i’ve come home to find it sat there just humming away with the drain pump on powering off and on will make it spin, and it finishes cycle.
The brushes seem fine, spins to 1200 without any odd noises or big sparks from the motor. 9 times out of 10 the aborted spin will be the full spin and not the short/synthetic spin, although i’m sure i’ve caught it once stopped on a short spin.
Just noticed the brushes are the black plastic ones, not the later white ones. Would this cause this? It always spins fine when i’m watching it.
Just wondering whats likely to be causing this. Dodgy timer that won’t advance properly? Fault on the main board? Cheap brushes? Weaker suspension making it not balance properly? Or just overloading?
Its already burned out one drain pump from being sat there with it on for hours, so hopefully i’ll solve this before it does it again, or she might get a new washer.
Thanks,
Danny
