My hotpoint aquarius wma 30 had a puddle under so upon inspection I can see a hole in the outer drum,would this be caused by collapsed bearings as is very noisy spinning?
Which parts do I need to repair/cost and is this economical as the machine is 6yrs old?
If not economical whats a good machine £300-£400
Thanks in advance for any help.
Richy
A bearing failure shouldn’t cause a hole in the drum, however a bearing failure that has gone un checked for a while will require a fairly expensive repair in any event.
New drum rear half, possible drum spider, major strip down.
Our own ISE machines are well worth looking at. 😉
