Hotpoint Aquarius WMA37 washing machine – drum doesn’t turn
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Aquarius WMA37 washing machine – drum doesn’t turn
  • #19859
    handsthatdodishes
    I put a small load of mattress covers on wool wash. The machine filled but the drum wouldn’t turn although it sounded as though something was trying to turn it. Tried to get the lid off but only got as far as the two screws on the side.
    Is this likely to be the belt and if so
    is it difficult to replace,
    where can I get the part
    and how do I get the lid off
    handsthatdodishes
    #184805
    Dave_Conway
    Re: Hotpoint Aquarius WMA37 washing machine – drum doesn’t
    Carbon brushes worn, motor failure, possibly the belt, bearing failure causing the belt to come off, damaged wiring….
    Any number of possibles I’m afraid.
    Check the repairs@ link below for an engineer to sort for you 😀
    #184806
    KevB
    If it is is the Carbon brushes that are worn, then it’s a 10 minute repair once you have replacement parts to fit… and if you’re half-way competent. Costs under £15 as a DIY job
    #184807
    Washman
    The Motor is under the wash tub on this model so not as easy as earlier machines with motor in the top of wash tub
    SWITCH OFF AND UNPLUG BEFORE REMOVING ANY PANELS
    Mike
