hotpoint aquarius wma54
  • #54377
    glennchambers
    some help required please. the drum on my washing machine won’t spin. i have taken the top and rear panels off, i found the drive belt off, i checked the motor and this spins freely i tried turning the drum and there is no movement whatsoever. with this i am thinking probably bearings? can anyone confirm this for me please? also is this an easy job to do? and is it expensive or is it easier/cheaper to get a new machine? thankyou.
    #319387
    Re: hotpoint aquarius wma54
    If the machine has been making a loud noise for some time then you may regret ignoring it.
    In most cases when it has got bad enough to throw the belt off the bearings and drum support shaft will be damaged beyond repair.
    It may well have the cheaper, Indesit 30mm bearings as well.
    The only satisfactory repair would be a new drum rear half & seal plus a new drum support shaft.
    Not a simple DIY task and very expensive.
    Leaks and noises should be investigated and attended to ASAP.
    If this machine is repaired with the 35mm shaft and rear half it would still be better than any sub £300, new machine on the market IMHO.
    Also the Indesit Company will do the whole repair for £115.00, just don’t let them pressure you into paying any more for extra warranty and descaler etc. 😉
    #319388
    glennchambers
    ok thats really helpful thankyou.
