Re: Hotpoint Aquarius WML 520 Leaking Again
Have you taken out the soap draw and thourougly cleaned the softener syphon,take it apart and clean all holes you can see.
before you put it back re assemble, fill the softener dispenser over the sink and see if it syphons out until no water is left,if it doesn’t check your cleaning.
jets which shoot the water down can become crudded up so something like a stiff washing up brush can help clean the roof of the soap drawer.
Sump hose could be blocked too,doesit spin well? does it pong a bit when not used for a day as this can be a sign that stuff is trapped in the sump hose.
You could also need a soap draw if this doesnt cure it.
BG
