Re: Hotpoint Aquarius WML540 washing machine banging on spin
It does sound like it’s bearing failure, have you taken the belt off and spun the drum by hand? if it runs silent then the bearings are probably okay and the problem lies elsewhere.
If the the bearings have failed and your machine is under five years old Hotpoint will cover the whole repair for £110. If it’s over five years old it will probably be cheaper to replace rather repair.
Having had a quick look at the drawings there are quite a few versions of your machine, the random choice I took indicates your machine has the Inde***t sealed tub syndrome :rolls:
HTH 🙂
Don
