Hotpoint Aquarius WML560 washes but won’t spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Aquarius WML560 washes but won’t spin
  • #87333
    al_b
    I’m flummoxed by this.
    The machine washes and rinses perfectly well, fills heats and empties OK. However when it gets to the spin part of the cycle it constantly turns over at 100rpm or so and has a number of attempts to run up to the full spin speed, but never gets going properly. Changing the spin speed setting makes no difference. After 15-20 minutes or so it stops, unlocks the door, flashes the lights etc.
    The vertical lights showing are the lock, end and spin.
    By my reading that’s fault code F11 “drain pump can’t be activated” but the pump works fine as it drains the water and runs all the time the spin is trying to get going. I’ve had the drum to pump pipe off and it’s all clear, no foreign objects, very little gunged up soap and the hose isn’t blocked. The pump itself turns over freely when sticking a finger in and moving the rotor.
    If I’ve read the lights wrong it would be F05 which reports a drain blockage issue.
    The drum turns smoothly and the belt runs true – so the motor speed is consistent and shouldn’t be causing the out of balance detection to kick in (my initial suspicion given the behaviour)
    The label on the back reads
    L2 (54511) WML560P 808280202
    the CE one has 195049127 along the top
    Type LB2006TRF
    Any thoughts? If any more information is needed let me know.
    Alan
    #434528
    Re: Hotpoint Aquarius WML560 washes but won’t spin
    First three lights from bottom upwards on steady is F07, heater relay stuck, faulty pcb most likely cause.
    #434529
    al_b
    From the bottom up the row of lights are
    Lock
    End
    Pump out
    Spin
    Rinse
    Wash
    So the ones I’ve got are nos 1,2 and 4.
    The error code drawings use only 5 of the 6 lights, so if the Lock one is ignored it’s F05 ‘pressure switch or pump’
    Or am I reading it totally wrong?
    #434530
    There could be an error in the official manual as far as the description of each light is concerned but the position or ‘number’ of the lights is the same regardless. See attached image.
    1+2+4 is F11, pump cannot be activated.
    You do have an Indesit machine which is known to have some of the flakiest electronics on the market so anything is possible. 🙁
