Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Hotpoint aquerious Wf560
- This topic has 10 replies, 4 voices, and was last updated 18 years ago by
crazy1.
March 25, 2008 at 10:58 am #35508
crazy1
ParticipantIm having massive problems with my washing machine
S/N 49119014
it seem to be letting water in through the inlet and instead of going in the drum it going straight out the waste pipe
the buttons are flashing the on/offplus the wash enhace and the reduce creases.
just wondered if anybody had any words of wisdom
thanks Dave
March 25, 2008 at 11:26 am #246851iadom
ModeratorRe: Hotpoint aquerious Wf560
It would help if you gave us the left hand flashing lights by number from the top down.
You could also check your outlet pipe, if it is too low or has dropped over at the back of the machine the water will not fill into the drum but drain away all the time, have you moved the machine recently?
It could also be syphoning which is again due to an outlet plumbing fault.
March 25, 2008 at 11:34 am #246852crazy1
Participantit is the top 2 lights there are 5
yes i have moved the machine
it also pumps wen its off. power at the wall but machine switched off
thanks jim
March 25, 2008 at 4:44 pm #246853iadom
Top two lights is F12, supposed to signify a communications error. It means that the two PCB’s are not on speaking terms.
It could just be a loose contact on either of the boards caused by moving the machine or a fault on the main control PCB itself.
When you say it pumps when its switched off, do you mean the water still drains out, or that you can actually hear the pump running?
Don’t forget you are covered for parts for five years from date of purchase, you only have to pay the labour.
The PCB’s are quite expensive if required.
March 25, 2008 at 9:01 pm #246854crazy1
Participantthe machine is filling and draining at the same time.
i will check all the conectionsproblem i have moved to australia so getting the parts maybe a problem….
the elements have gone in my dryer and hotpoint sent me a message saying they have been discontinued
March 25, 2008 at 10:26 pm #246855iadom
Bloody hell, I didn’t think you had moved it that far, 😆
Some of the lads that post in the Australasian forum may be able to advise you about spares availabilty down under etc.
It does sound as though the PCB has failed, they are Indesit electronics after all, sadly known to be unreliable . 😥
March 25, 2008 at 10:33 pm #246856crazy1
ParticipantRe: Hotpoint aquerious Wf560
haha tell me about it ,,,,
like the oldham tinkers bit ,,,
my teacher used to be in the band think he is dead 😥
and father in law used to be there roadie 😀March 25, 2008 at 10:42 pm #246857iadom
My mum used to live two doors away from John Howarth, he is still playing at one or two local venues.
By eck, its a small world. 😆
March 26, 2008 at 12:52 am #246858Penguin45
Failed triac to pump on power board……..
Moved to Oz forum – the lads there may be able to point you to a supplier. The Ariston version is sold as a premium product :rolls: .
March 26, 2008 at 4:21 am #246859crazy1
Participantcan i have a link to the aussie forum and is this fixable
thanks
David
March 26, 2008 at 6:11 am #246860bigsmokepiker
Try Arisit For Parts
Phone 1300762219 (Melbourne) -
