Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint, Aquirious – Drum does not spin! Please help me!
- This topic has 9 replies, 3 voices, and was last updated 18 years, 9 months ago by
DannySee.
July 23, 2007 at 11:07 am #29192
DannySee
ParticipantHi There!
Looking for some help to fix my washing machine.
I have a Hotpoint, Aquirious and its about a year old.The machine will start up on a cycle, the red lights come on but the drum doesn’t spin.
Then the lights start to flash.water is flowing through the machine, but the problem seems to be with the drum (Not spinning).
Can some one instruct me on fixing this problem?
Thank you
Rob…July 23, 2007 at 1:13 pm #222259Martin
ParticipantRe: Hotpoint, Aquirious – Drum does not spin! Please help me
DannySee wrote:the red lights come on but the drum doesn’t spin.
Then the lights start to flashThe lights down the left hand side, which ones are flashing? (i.e. Counting from the top red LED being no1 etc) 😉
July 23, 2007 at 1:29 pm #222260DannySee
The on/off light on the right hand side is flashing and two lights of the four or five on the left hand side also.
Would this be a warning that there is a problem with the drum.Possibly the bushes are warn?
July 23, 2007 at 1:36 pm #222261Martin
Yes but which lights (specifically) counting from the top?
July 23, 2007 at 1:54 pm #222262DannySee
July 23, 2007 at 2:03 pm #222263Martin
Danny are you not reading the question I asked? Which flippin’ lights are flashing my friend is the question (why repeat your previous post?) :rolls:
July 23, 2007 at 3:34 pm #222264DannySee
My apologies mate…
The on/off light is flashing
And the lights on the left counting from the top down
Light three (Rise Hold)
Light four (Mini Load)Many thanks
July 23, 2007 at 6:43 pm #222265iadom
ModeratorRe: Hotpoint, Aquirious – Drum does not spin! Please help me
Fault F03 or NTC fault. The NTC is the water temp sensor, it could be faulty or it may be loose wiring connections or even failure of the main PCB.
July 24, 2007 at 9:03 am #222266DannySee
Thank you
Could you confirm where the water Temp sensor is located within the machine?Also what part number do I need to purchase?
Many Thanks
Danny
July 24, 2007 at 9:34 am #222267iadom
I would not be purchasing anything until the exact fault has been determined. The error codes are only a guide as to the possible cause of the fault. The NTC is situated within the heating element itself. However should the fault turn out to be the main control PCB you would be advised to leave well alone and take advantage of the five year parts guarantee that you have.
Jim. -
