hotpoint aqxgd169pm
  • #90172
    mikehha
    Good evening and any help would be much appreciated. m/c door locks but nothing else no water, pump,or motor.and then if its on a spin cycle and you pause the m/c the door won`t unlock untill you turn off the power and then put it back on. ❓ poss the board.
    #443936
    whitevanman
    Re: hotpoint aqxgd169pm
    check the carbons ?
    #443937
    kaibart
    Yes I would have thought pcb as it’s a brushless motor??
    #443938
    whitevanman
    well if the pcb needs changing check the serial number as wiring harness may need changing due to a mod
