hotpoint aqxgf149 p1
  • #60745
    dealdd
    got this hotpoint aqualtis been out to it twice now first time remove one of them colour catcher sheets from pump. then month later gets a call does wash fine but dont spin just stays on one minuet count down. if customer put on spin it spins out fine. i have removed sump and checked for further blockages. heater and valve all ok. i have got customer to do an empty wash today to see what happens. has anyone come across this before??
    #343458
    allan73
    Re: hotpoint aqxgf149 p1
    Have you checked the heater for low insulation ?
    #343459
    dealdd
    yes but havent changed it. would this cause it to stick on 1 min remaining
    #343460
    whiskey_six
    Common faults on Hotpoints, 1 min left to go, 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time it’s caused by the heater or the NTC.
    Now and again it can be caused by the Module but this tends to be rare unless you can hear the heater relay chatter during the wash cycle
    #343461
    shaun67
    I had a similar fault a couple of weeks ago ..Was heater on mine that was down to earth..
    Shaun
    #343462
    dealdd
    have fitted element and thermistor and still stops 1 min from end but only on white wash
    #343463
    dealdd wrote:but only on white wash
    Tired Askoll pump running hot then slows when very hot water has to be pumped away?
    Try running it on a spin only for 5 mins or more, if it gets too hot to touch then there’s your problem. 😉
    #343464
    dealdd
    customer said all water has gone from drum just has not spun. if they put it on a re spin straight after then it spins ok?
    #343465
    Knackered pump I reckon………
    #343466
    helo_75
    wouldnt u get an f11 fault if it went o/c?
    #343467
    helo_75 wrote:wouldnt u get an f11 fault if it went o/c?
    Absolutely correct, but I’m suggesting that in this case the pump windings are electrically OK but the pump bearings are not in the best of health? Probably gets red hot after a few minutes running and slows up big time in the process.
    Have you ever seen an Askoll pump winding overheat and melt it’s housing when a Color Catcher gets in there?
    Oh! Another thought just crossed my mind….that ruddy blue flap valve in the pump outlet….take the darn thing off, see if that sorts it. 💡
    #343468
    dealdd
    ok cheers for help booked in for tuesday now will just fit a pump and go from there
    #343469
    allan73
    Did you get to the bottom of this dealdd,I’ve got a similar fault to look at Monday ?
    Allan.
