Hotpoint AQXGF149PIUK F01 Fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint AQXGF149PIUK F01 Fault
  • #68064
    a1al
    Hi Everyone
    Been out to this washing machine it will not do anything at all.
    I know the fault codes gives motor/module fault
    Motor is three phase.
    No earth leakage faults found
    Has Anyone come accross this type of fault??
    Thanks for looking.
    #369484
    A1engineer
    I’m afraid it’s one of these faults it could be motor or module mibee even the wiring, you can check the motors for resistance of the 3 fields and tacho
    A betting man would say module fault tho
    Kev
    #369485
    a1al
    Re: Hotpoint AQXGF149PIUK F01 Fault
    Thanks for your quick reply Kev
    Al
    #369486
    johnnyj
    The 3 phase motors dont give much problems, it will probl,y be the module but i would plug in another motor harness 1st just to confirm cheersJJ
    #369487
    a1al
    Hi JJ
    What do you mean when you say…
    ”i would plug in another motor harness 1st just to confirm”
    Do you mean try new wiring and motor?
    Al
    #369488
    johnnyj
    You can get a new harness from the motor to the module plug one in and see if it cures the fault if it doesnt your looking at a module, i usualy have a harness to try 1st.
    #369489
    a1al
    Thanks for that JJ
    I’ll give that a go as new module is £69.00 + vat + smart card @ £11.00
    #369490
    a1al
    Hi Everyone
    Tested motor windings all three had same resistance reading and no leakage to earth.
    Tried the harness of an old machine, still F01
    Ordered up new module and card and machine is now working fine. (fitted module a week ago)
    Thanks again.
