Hotpoint AQXXF149PI H2O then F-01 errors
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint AQXXF149PI H2O then F-01 errors
  • #69982
    TopHound
    This machine has been reliable although I changed a noisy pump a couple of weeks ago. It worked fine for several washes afterwords.
    Now it doesn’t fill at all, then reports a H2O error and, if left switched on, eventually changes to reporting a F-01 error.
    The water supply is ok and the solenoids both work ok (I independently powered them and water flowed ok), so I assumed that it must be the controller (a Mk 6 board).
    I’ve replaced it with another from EMW Electronics (programmed for this machine)… and get the same results. I checked the door interlock (just in case there was a voltage drop across the contacts) but that seems ok too.
    Any idea what else I may have missed?
    #376661
    Re: Hotpoint AQXXF149PI H2O then F-01 errors
    TopHound wrote:eventually changes to reporting a F-01 error.
    Motor fault error I believe. 🙁
    Have a little read of THIS POST as it seems you’re not the only one! 😯
    #376662
    TopHound
    At EMW’s suggestion, I returned both original and their replacement controller so they could read some of the internal logs to see if it would shed more light. They sent be a controller (back in just less than 24 hours of me posting the original) with a later software version… and now it works!
    EMW said that sometimes intermittent earth leaks on the motor when warm can cause the software to loose settings – I don’t think too much of the board’s EMC levels if that is really the case.
    If the fix doesn’t stick, I’ll post a further update. Otherwise, no news is good news.
    #376663
    We don’t think much of Indesit electronics period, they suck big time. :rolls:
