Hotpoint AQXXF149PMUK
  • #87452
    A1applianceservice
    I have a customer with one of these HP washing machines with a reported F05 fault.
    I went and had a look and found it was full of water but unable to start or switch the machine off from the facia and no door lock light on the display. The filter was badly clogged. Upon clearing filter managed to get the interlock to work after several attempts and pump kicked into life. Tried on wash cycle but will not fill even with the lock light on. More blockages in sump or pressure switch tube ?
    Can anyone advise what may be causing this (PCB ??)
    Thanks, await your reply.
    Jaz
    #434889
    wilf
    Re: Hotpoint AQXXF149PMUK
    had the same thing on one of these last year cleared the pump it then pumped then nothing put it down to pcb as everything else tested ok. horrible machines thankfully not too common.
    wilf
    #434890
    whitevanman
    did u recalibrate psw with 1.5 litres of water down soap drawer?
