Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint/Ariston washer/dryer CAWD 129EU
- This topic has 6 replies, 2 voices, and was last updated 10 years, 11 months ago by
ken_mayall.
May 14, 2015 at 8:05 pm #84974
ken_mayall
ParticipantOn a wash cycle the m/c fills with water and then drains with all 5 lower led’s flashing rapidly. On a rinse cycle it fills,the drum starts to rotate but then same thing happens. On spin cycle drum rotates (distribution speed) but then as above. This happens on all progs after approx. 90 seconds. With all lights (5) flashing pump runs continuously and m/c will not cancel. It has to be unplugged to switch off. Any ideas would be very welcome. Ken.
May 14, 2015 at 9:03 pm #427338iadom
ModeratorRe: Hotpoint/Ariston washer/dryer CAWD 129EU
From your IP I am guessing you are in France, also the EU at the end of the model number suggests a non UK machine.
Sadly that model number does not relate to any of the technical information we have for UK sold machines.One of the more recent types of error code displays does flash a full row of lights along top or bottom but the error codes on these is shown by a combination of the right hand vertical lights staying on and not flashing.
May 15, 2015 at 9:20 am #427339ken_mayall
ParticipantRe: Hotpoint/Ariston washer/dryer CAWD 129EU
Thanks for your reply and yes there are some vertical lights on, there are six lights on the panel. From top to bottom the lights on are 3,4 and six as well as the 5 continuous flashing along the bottom. Does this match any of the UK made machine’s error codes ? Any ideas ? Cheers, Ken
May 15, 2015 at 10:06 am #427340iadom
On this model type the error codes are given by the BOTTOM five vertical lights counting UP from the bottom, lowest light is light 1 for error codes.
May 15, 2015 at 10:44 am #427341ken_mayall
Ok in that case the lights on are 1,3 and 4.
May 15, 2015 at 1:39 pm #427342iadom
F13, fault on dryer side, even when not in use it will self test. The dryer ntc is a known weak point but it can also be broken wires to ntc, blocked dryer duct, failed dryer fan etc.
May 15, 2015 at 2:47 pm #427343ken_mayall
Ok many thanks for your help, I will check it out
