Hotpoint auto washer WF 740
  • #64224
    winker
    got this machine stripped and it has a 30mm spider shaft and bearings not the usual 35mm.It is wma type and whilst I can find a bearing kit 30mm I cant find the spider.Anyone know the part no. please
    steve
    #356440
    Re: Hotpoint auto washer WF 740
    There isn’t one but Qualtex do a pattern one.
    30mm spider
    #356441
    winker
    I assume I could order 35mm tub rear with bearings and 35mm spider ??
    #356442
    Thats what I advise and do for most of my customers if they want a proper repair.
    It just depends how much they are prepared to pay.
    Are you absolutely certain it has the 30mm bearing and shaft.
    All of the screwed drum versions on Partfinder only show the 35mm shaft & bearings for this model?
    EDIT. I have checked all of the tech info that I can and there is no mention of this machine having the 30mm shaft/bearing. Has it been ‘doctored’ ❓
    #356443
    winker
    Agree with you totally,took me by surprise,my digi calliper says 30mm.As for neutering I dont know,could you be bothered.
    thanks for your help
    steve
    and of course the tub rear half has a different hub centre for smaller bearings
    #356444
    If I am not mistaken there is actually 30mm or 35mm embossed on the back of the drum rear somewhere.
