Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint B/I double oven BD81, light coming on?
- This topic has 5 replies, 4 voices, and was last updated 20 years, 6 months ago by
Tubs.
September 23, 2005 at 11:10 am #12129
Tubs
ParticipantHi all
Have no wiring diagram for this model, (before I pull it all out)
Can anyone confirm flo tube on display panel is suppose to light up when control panel cooling fan cuts in if oven gets too hot (after switching oven off) normally fan just runs for a period of time after. Not seen it bring flo tube on aswell. ❗
Regards Steve
September 23, 2005 at 12:39 pm #147999Seamy
ParticipantRe: Hotpoint B/I double oven BD81, light coming on?
Don’t think the fan should have anything to do with display, as far as i’m aware theres a t’stat on the top of the oven cavity that comes on when it detects heat & switches off fan after it has cooled down, the display lamp gets a feed through the selectors, whether oven, or grill is selected, so look towards at a faulty switch if it stays on??
September 23, 2005 at 12:49 pm #148000Tubs
Hi seamy, my thoughts exactly. Does seem to imply that the selector switch has welded itself together on the selector switch side, so of course the light would come on anyway when the selector switch is turned. Must be getting a feed when toc cuts in when cavity gets too hot.
If the light does come on with fan its the first ive ever seen. Looks like i have no choice but to pull it all out 😥
Thanks Steve
September 24, 2005 at 8:48 pm #148001bobokines
I believe the light comes on whenever ANY energy regulator is turned and stays on for a preset time determined by the module in the top cavity.
Probably doesn’t help without a wiring diagram though.
Bob
September 25, 2005 at 5:59 pm #148002burns
I guess I would start with a fluorescent tube and replace the starter which is situated in the rear (near terminal block), usually the tube gets changed and becaues the starter is hidden it gets forgotten about.
Possible choke could be faulty but these usually are very reliable.September 26, 2005 at 11:20 am #148003Tubs
Hi Guys
Thanks for the input.
Oven all works ok, light comes on when it should (when regulators are turned etc) just decides to fire up flo tube when cooling fan cuts in. As you know could be a couple of minutes after ovens are turned off. Unit appears not to have trigger board (partfinder Cd).
Will post outcome, back there next week armed with selector switch ❗
Steve
