Can anyone help with wiring diagram for this unit??
problem is no heat during cycle. Suspect module as there is power to and from heater but module is not switching the neutral to complete the circuit.
Just want to check diagram to ensure noting else can cause it as customer advised me that another repair agent had tried a module in it but it did not cure fault.
Dispenser, drain, circulation motor and temp senser appear ok
