Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Hotpoint BD31 main Oven not working
- This topic has 5 replies, 2 voices, and was last updated 8 years, 9 months ago by
Gwmpy.
June 30, 2017 at 8:29 am #91564
Gwmpy
ParticipantHi,
Main Oven not working. Tripped the RCD and as usual, just changed the element which solved the problem. This time, changed the element(the element had gone), but this time, Oven will not work. Fan is working. Could it be the thermostat? If so, is there an easy way to check? Also, looking at your spare parts, please could you point me in the right direction for the part, if needs be I’ll phone.
Before I do, just need to know if there is an easy check before pulling out the oven and taking it apart.
Many thanks
GJune 30, 2017 at 8:47 am #448581electrofix
ModeratorRe: Hotpoint BD31 main Oven not working
I have deleted your duplicate post
there are various things it could be
selector switch check for blown contacts
thermostat you can check this with a multimeter
take it you have double checked the wires to the element
also much as it is very rare never assume the new part is ok check it just in case
June 30, 2017 at 8:55 am #448582Gwmpy
ParticipantRe: Hotpoint BD31 main Oven not working
Hi Dave,
Sorry for the duplicate post.
Checked the new element O.K.
So when checking the Thermostat with a multimeter, looking for resistance? Does this mean I have to get into the back of the Oven? many thanks for all your help.June 30, 2017 at 8:59 am #448583electrofix
the thermostat connections are behind the knob so take the top off. it has 2 connections. if mutimeter has a buzz position use this. take 1 wire off and check between the 2 connections. if it buzzes it ok ( well its ok in the sense of the elelemt will get hot but if the contacts are welded it will overheat when you get it going )
June 30, 2017 at 10:09 am #448584Gwmpy
Hi Dave,
Checked the continuity. Helps to have the Small oven Thermostat next to the main oven. Pulled off the wire, no buzz between connectors. The small oven thermostat has when pulling off the one wire 🙂
So it points to the Thermostat. BTW, is there a way to just by-pass the thermostat (Temp wiring) just to see if the element heats up, if only for 5 seconds?
Again, many thanks for all your help
GJune 30, 2017 at 9:28 pm #448585electrofix
yes link the 2 wires
