hotpoint bd32
  • #49007
    Galway
    hi all
    the top oven/grill are not working but the cooling fan and light comes on. i am thinking the selector switch .but does the thermostat come as part of this or do they come separately
    thanks
    #298469
    Re: hotpoint bd32
    Both top & bottom ovens have separate stat and selector, a few different ones, exact model number with suffix and serial number required TBH.
    #298470
    Galway
    Re: hotpoint bd32
    thanks Jim ,but the sticker with model info has worn away as usual,its a cream colour so i am guessing its bd32n?
    what do you think
    thanks
    #298471
    Re: hotpoint bd32
    Still comes down to two different stats dependant on date code, selector switch is the same regardless, a 6201720.
    Top oven stat is either a Rathgeber, part number 6603477 or a Diamond H, part number 6102338.
    It would seem that these are not interchangable.
    #298472
    Galway
    Re: hotpoint bd32
    thanks Jim for that .on top cover this was written with marker 09/05 78327
    dont know if that has anything to do with date code.
    thanks
    #298473
    Re: hotpoint bd32
    Not sure but the stat changed to a Diamond H in 2003.
    Galway
    Re: hotpoint bd32
    thanks i will chance that then and see.
    #298475
    Galway
    Re: hotpoint bd32
    ordered the rathberger stat but when i went to fit it it was a diamond h but the rathberger fits no problem.is this ok or is there a reason why it has to be the diamond h.
    thanks
    #298476
    Re: hotpoint bd32
    No idea, the usual reason manufacturers change supplier is cost, although they will tell you its an ‘upgrade’ :rolls:
