hotpoint bd32 cooker fan not working
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint bd32 cooker fan not working
Viewing 6 posts - 16 through 21 (of 21 total)
  • #338717
    maxx
    Re: hotpoint bd32 cooker fan not working
    try contiuity check on wiring to and from stat .might be broken inside insulation and parting when moved? just a guess.maxx.
    #338718
    slyp98
    customer still having trouble with this oven working fine but it wont stop heating keeps heating at fullpower even though stat is down at 80 degrees , any help thanks
    #338719
    loopey
    cooling fan slow or not working , iff it has one , is my guess
    A1engineer wrote:stats are normal 1 is n/c 1 is n/o
    yes correct n/o is usually a thermister type , dont get me wrong here all depends how its meterd , a mega wont show it as as a thermister type , i may be wrong on WHAT TYPE
    IT HAS ,, any ways hope this helps
    phil
    #338720
    slyp98
    fan is working fine loopey , i need a wiring diagram really but i have no rating plate/sticker nothing to go on !!someone else was at it replaced the fan last year !
    #338721
    gandh1
    slyp check the user manual, theres normally at least 3 spare model nos supplied with these ovens, i always stick on on the manual front/iside cover when we install one, and an additional one to the rear if spare. also see if cust still has the guarantee card as some came with teh labels pre-stuck to them too. hp usually have a large 2×3″ label on rear of there cookers too, with wattage and voltage specs, good chance on this too ??? if your really stuck take a pic on your phone of the fascia panel as iirc they changed the knobs, and timer, bd32 had solid knobs, 5/6 button timer, bd32mk1 had push knobs and 5/6 buttom timer and mk2 had 3 button clock and push knobs
    #338722
    slyp98
    cheers gandh1, how do you mean push knob is this with the spring between the grip and the dial ? this model has 3 knobs, they can be removed by pulling them off the switches one piece construction with spring circlip around shaft of knob it has 6 push button timer/clock also . it sounds like its a bd32p mk 1 i’m afraid the guarantee and user manual are long gone . are diagrams available for the mk1 ? or do i still need a pnc cheers
