Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint bd32 cooker fan not working
- This topic has 20 replies, 8 voices, and was last updated 15 years, 3 months ago by
slyp98.
December 13, 2010 at 10:58 pm #59561
slyp98
Participanthad a look at this fan oven today , the element works fine but not the fan or the interior light , the fan has no power coming to it from the stat / switch , i see there are 2 cut outs on the top of the oven housing i can get continuity from one but not the other , anyone know what these cut outs do ? are they related to the fan problem ? thanks
December 14, 2010 at 9:21 pm #338703A1engineer
ParticipantRe: hotpoint bd32 cooker fan not working
stats are normal 1 is n/c 1 is n/o
sounds like a faulty selector switch to me
December 14, 2010 at 11:10 pm #338704slyp98
i checked the switch its a mechanical one with metal strip contacts , continuity when switched on and none when its off cant test it for anything else really , thermostat is behind that has power going to it and coming out the other side but the wire leading to one side of the fan from the stat is not carrying any current
December 17, 2010 at 6:31 pm #338705slyp98
replaced thermostat today , fan starts now happy days thanks for the help
December 21, 2010 at 7:13 pm #338706slyp98
well that lasted 24 hours , fan stopped again , same as before no power from the stat , i have power coming into the stat but none going out . just wondering if anyone has diagrams for wiring on these fan ovens thanks
December 21, 2010 at 8:28 pm #338707iadom
ModeratorRe: hotpoint bd32 cooker fan not working
Several different models of the BD32, need the full model number plus commercial code and serial number if possible.
December 21, 2010 at 9:38 pm #338708slyp98
all i can find is bd 32p nothing on the door surround where else should i look
December 21, 2010 at 9:47 pm #338709iadom
Sadly these ovens often had a stick on label that either comes unstuck or burns off. Its usually dead centre, front at the bottom of the main oven.
December 22, 2010 at 10:56 am #338710slyp98
well thats not there anyway ,
December 30, 2010 at 11:11 am #338711slyp98
does anyone have wiring info on one of these any model will do im sure the changes were not huge from each model thanks also as a side , the customer has aluminium foil in the bottom of the oven would this cause problems with the stat??
December 30, 2010 at 3:51 pm #338712Martin
Sorry, don’t have a wiring diagram but I’m with A1engineer on this in that I reckon it is the main oven selector switch also.:wink:
Trouble is that a BD32P has no less than 3 variant main oven switches and it’s important to get the full model number and commercial code for it. The 3 different switches are: –
C00227335
C00261547
C00196448I wonder if the full model no’s are stamped on the back panel?:idea:
December 30, 2010 at 8:56 pm #338713boselecta
ParticipantHi
I had a problem similar to this last year on this model in that the interior light and the element came on but not the fan.
I found the bulb blown and the bulb holder had a blow hole in it.
Replaced the stat and bulb holder and ok.I would be looking at what is shorting and blowing stat, good luck.
December 31, 2010 at 11:02 am #338714slyp98
cheers guys
January 6, 2011 at 7:40 pm #338715slyp98
hi all , i was back at this cooker today turned on selector switch nothing , tested thermostat i replaced previously , seemed ok i had another spare to hand so i put that one in and it was working , i swapped it for the original i fited and hey that worked also ?? , i have a digital temp reader and probe on my meter so i stuck the probe in a hole at the back of the oven cavity and turned on the oven to max. 220 c and the heat kept going 230 ,,, 240 ,,, i turned it off at 246 c element was bright red fan working fine , is there a problem with the stat still ??? or could it be an over heat protection prob ? anyone use meters for checking temps ?? thanks fellers
May 8, 2011 at 3:35 pm #338716slyp98
still having trouble with this cooker guys any ideas , it keeps overheating and cutting out i have replaced the thermostat what else can be causing it to do this ?thanks
