Hotpoint BD32 tripped & now the Main oven does not heat Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Hotpoint BD32 tripped & now the Main oven does not heat This topic has 7 replies, 2 voices, and was last updated 16 years, 4 months ago by thecount. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts December 2, 2009 at 1:58 pm #50618 thecountParticipant The other day our integrated Hotpoint BD32 tripped the fuse box & now the Main oven does not heat up at all, but the top small grill/oven works ok? Any ideas before I book an engineer at £50+Vat call out? thanks in advance. December 2, 2009 at 2:00 pm #305466 kwattKeymaster Re: Hotpoint BD32 tripped & now the Main oven does not h The fan element, this one, would be the most likely cause of it and, it’s easily checked with a multimeter. HTH K. December 2, 2009 at 2:06 pm #305467 thecountParticipant Re: Hotpoint BD32 tripped & now the Main oven does not h hope you are right as it doesn’t look expensive. Don’t think this is something I can check myself, so a callout sounds like a definate then. thanks for your reply January 13, 2010 at 3:05 pm #305468 thecountParticipant Re: Hotpoint BD32 tripped & now the Main oven does not h you were right, and I got it replaced. now one side of the grill has gone! any idea what I would need to replace? thanks in advance January 13, 2010 at 3:09 pm #305469 kwattKeymaster Re: Hotpoint BD32 tripped & now the Main oven does not h Hi, It should have two of these elements fitted to it forming the grill. Regards K. January 13, 2010 at 4:43 pm #305470 thecountParticipant Re: Hotpoint BD32 tripped & now the Main oven does not h looks very similar, hopefully its easy to fit as it took the last guy 5 mins to fit that replacement fan. you think its easy? January 13, 2010 at 4:46 pm #305471 kwattKeymaster Yeah, those elements are very straightforward to replace normally. K. January 13, 2010 at 9:12 pm #305472 thecountParticipant Re: Hotpoint BD32 tripped & now the Main oven does not h thanks 🙂 Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
