Hi Guys.
Be grateful if anyone can solve this problem.
The error code showing is, the 1st Green light is flashing, green light on the left. its seem to be working, but then it beeps, then starts to flash.
If i add water inside, the pump drains it off, no blockage.
I have removed, both pumps, no blockage, impeller turns with no problem.
There was water, at some point on the bottom of the unit, but none when inspected.
The Float switch, seems to be fine, clicks on / off.
thanks
