Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint bf162
- This topic has 5 replies, 2 voices, and was last updated 17 years, 7 months ago by
fasetester.
September 3, 2008 at 1:11 pm #39195
fasetester
Participanthi guys hotpoint intgrated dishwasher bf 162 when the kitchen door is removed. should the the dishwasher door stay down when opened.
as it does not seem to open down fully. and would spring back up or does it need the kitchen door to balance it. thanks fasetester 🙂
September 3, 2008 at 1:28 pm #261616Martin
ParticipantRe: hotpoint bf162
Without the decor door panel in place the spring tension will not allow the door to stay open. However, the spring tension can be adjusted to suit the respective weight of most types of decor door panel, from mdf composites to solid hardwood. You’ll find an adjusting screw in the top corners of the tub will allow slackening or tightening the tension for the perfect balance. 😀
HTH Fase? 😉
September 3, 2008 at 2:40 pm #261617fasetester
thanks martin for your reply. is that the 2 hex screws at the top with wire rope. should the door go down the full way as it gets near the bottom it starts to catch. fasetester 🙂
September 3, 2008 at 2:56 pm #261618Martin
fasetester wrote:thanks martin for your reply. is that the 2 hex screws at the top with wire rope.
Yes those hex screws adjust the spring tension- not sure which way off hand but you’ll suss that one I’m sure.:wink:
fasetester wrote: should the door go down the full way as it gets near the bottom it starts to catch. fasetester 🙂
Now if the door “starts to catch” as you put it, I would suggest there may be a problem with the hinge or spring unit or even with the door catching the kitchen furniture maybe? Again you’ll have to take a closer look on that one.
Cheers! 🙂
September 3, 2008 at 3:30 pm #261619fasetester
thanks martin not when you pull it as it gets near the bottom 90 deg fasetester 🙂
September 3, 2008 at 4:00 pm #261620Martin
fasetester wrote:thanks martin not when you pull it as it gets near the bottom 90 deg fasetester 🙂
Yeah, yeah, I know what you’re saying so take a closer look and see what you reckon?…Cheers! 😀
