Re: Hotpoint BF162 Dishwasher Door Front
Are you trying to get the door off the Hotpoint BF162?
These are usually secured by a couple of screws either side that replace the original inner door panel screws with longer ones that go right through and into the door. Sometimes there are only two lower screws and clips at the top.
Loosen the lower screws on either side of the door and gently prise the decor panel away and you may be able to tell which are the long screws.
