Hotpoint BF162 DW aborting program
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint BF162 DW aborting program
  • #25822
    myfil
    Can anyone help with this one ? (I hate integrated DWs!!!)…
    Hotpoint intergrated dishwasher Model BF162 (S/N BF162 257 10626)
    (All pgms) Starts up, fills, then aborts pgm and pumps out. The 2nd indicator light flashes. That’s all.
    Leave it off for a while, switch on and start a pgm, and the whole process repeats.
    Motor is not seized, we changed the motor capacitor, pressostat not blocked, not flooding (base float flood switch is OK, base pan is dry) water is entering the wash pan OK, water softener not blocked.
    Any ideas, and the fault codes for this machine, would be greatly appreciated. Maybe it’s just the PCB, but maybe not. (We have not checked the motor for S/C or O/C (its hard to get at it))
    Mike
    #207732
    Re: Hotpoint BF162 DW aborting program
    Heater circuit, I think.
    bobokines
    Not so sure about the heater Chris. I would go for a fill problem.
    Perhaps the pressure switch?
    Bob
    #207734
    johnnyj
    Be the heater prob’ly down to earth, you will find inlet valve faults more than 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} time are heater related.
    #207735
    bobokines
    Yep.. I stand corrected.
    It always amazes me when these heaters fail. It always throws me.
    Bob
    #207736
    myfil
    Thanks for your help on this folks.
    Sorry if I sound dim, but why would a heater fault cause the machine (after filling) to suddenly abort the pgm and pump out?
    I’d have thought this would just be the preparatory rinse, and the heater not in circuit yet.
    (Does 2nd light flashing indicate a code, or is it just end-of-pgm?)
    Cheers
    Mike
    #207737
    myfil
    You were all right, as usual!
    The heater is open circuit.
    Many thanks
    Mike
