Hotpoint BF162 not working
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint BF162 not working
  • #33675
    the_big_1
    Dear All,
    My built in dishwasher allows water into the system and fills the filter area at the base. It then flashes the second light and empties the water. I removed the electrical valve from the main inlet and tested, seemed ok, removed the electrical valve to the filter and tested, seemed ok. Then powered the pump and that seemed ok too, any ideas?
    #239554
    the_big_1
    Re: Hotpoint BF162 not working
    Update:
    I just measured the resistance on the heater and it was completly open circuit so order a new one.
    Would this cause the same fault?
    I tested the switch relay that is for detecting sum pressure and it tests ok.
    Any ideas if it could be the heater or could it be that for some reason there isnt enough pressure in the sump to switch the pressure relay?
    #239555
    The error code you report is supposed to signify a fill valve problem, however the heaters are very prone to failure on these as are the electronics, it is not uncommon to get spurious error messages. The lights for heater failure should be either 4 or 2+4.
    Changing the faulty heater would be the first logical step.
    the_big_1
    When I change the heater and if it doesnt fix the problem, I am guessing its the electronics.
    Both the solenoid valves work and water gets to the sump no problem. If the pressuer relay is then operated and its tested ok, pump is working ok then I presume there is only the electronics left?
    If so, what are the chances of getting the spare?
    #239557
    All parts are readily available and unlike the Indesit washing machine PCB’s the dishwasher ones are not expensive.
    the_big_1
    where would be a good place to try and get a pcb from?
    #239559
    spares@ukwhitegoods.co.uk 😉
    Your machine is actually a BFI62, just checked on the module for that one and unfortunately it is a little more expensive than the BFI620 module.
    An e-mail to the above should get you price inc shipping etc.
    the_big_1
    Hi all,
    Replaced heater and it seems to be working now. Even though the fault light indicated water in issue.
    Can anyone tell me approx how long the dishwasher should run for on the cycle that is second from the right?
    It says in the manual that it does two pre-wash cycles then two heat cycles.
