looking to see if anyone can help with wiring diagram for this machine? The fault I have is that it over fills. Have checked the pressure pipe which is clear and the pressure switches changes over at the correct level to power heater/dispenser solid. The solenoid does not activate, heater does not come on and the motor fails to operate. Suspect module but would just like to confirm with wiring diagram or better still if someone has had this fault before?
Yes checked the wiring and I get feed from pressure switch to dispenser. But even though the pressure has clicked over the valve keeps on filling. only when you reset program/open door does it stop.
Sorry it should be BFI62 for the model
