I won’t if anyone can help. My dishwasher door will not close correctly. If the washer is turned on ready for a wash it will begin regardless of whether the washer door is shut or closed. I think there is an issue with a loop of wire (Possibley a latch) which is supposed to entered a opening in the door. For some reason this doesn’t work. Any clues or how I could remindy it?
going by what u are saying here it sounds as if the lock has jammed in the locked position while ur door was open?
looks like a new door interlock needed.
Thanks LJ. It seems as though the spring that enables the lock to….well lock, has broken. I’m going to try b and q or homebase for something that is simialar and may work ortherwise I will have to order the entire assembly. Thanks for the quick assistance! Now I have to stop a 1 year old hidding all the screws….. :rolls:
